1957 3 speed shifter finishes - NCRS Discussion Boards
  • Susan M.
    • January 10, 2011
    • 63
    Can someone tell me the correct finishes for a 1957 3 speed shifter? thank you.
  • Rod K.
    • 443
    Re: 1957 3 speed shifter finishes
    Susan,
    Shift lever was chrome and I believe everything else below the floor, housing, levers, bolts, etc., was cad plated.
    • Susan M.
      • January 10, 2011
      • 63
      Thanks Rod.
      • Mike M.
        • May 31, 1974
        • 8400
        rods to side cover were black phos or natural, not cad plated. shifter levers natural ,not cad. mike
        • Susan M.
          • January 10, 2011
          • 63
          Hi Mike, thanks for your reply. I have also seen some material saying the components should be zinc rather than cad. Is cad correct? Thanks S
          • Mike M.
            • May 31, 1974
            • 8400
            the handle id chrome plated as Rod stated in his post. all the piece i mentioned in my post are finished as i described. the rest of the shifter is silver cad plated.mike
            • Susan M.
              • January 10, 2011
              • 63
              Got it! Thanks Mike...
              • Rod K.
                • 443
                Thanks for clarifying that, Mike. I was talking about only the shifter itself, not the linkage or trans arms.
                • Susan M.
                  • January 10, 2011
                  • 63
                  Hi Rod, yes I figured that! Thanks again. Susan
