Removing TPS Decals from Tire Rim - NCRS Discussion Boards
  • Joe C.
    • February 7, 2011
    • 14
    I was wondering if anyone had suggestions as to how to properly remove damaged TPS decals found on run flat tire equipped cars. Not sure if there are any products on the market such as Goof Off that would desolve the adhesive without damaging the painted finish of the rims on my Collector Editiion. I have the replacement decals.
    Thanks.
    Joe Coschera
  • Paul H.
    • September 30, 2000
    • 688
    Re: Removing TPS Decals from Tire Rim
    Try soaking it in Goo-Be-Gone and then use a plastic credit card to gently remove it. A little heat from a hair blow dryer could help as well. Then clean it with a good polish.
    • Joe C.
      • February 7, 2011
      • 14
      Thanks. I'll give it a try and let you know how it turns out.
      • Keith B.
        • March 7, 2008
        • 928
        I bought a used wheel with the sticker still on. since my car does not have LTPWS I used the 3M adhesive remover and it came off
