69 BB water pump bolt with stud - NCRS Discussion Boards
  • G A.
    • February 18, 2010
    • 229
    Could someone please confirm or correct me. The water pump bolt (on a BB) with the stud for the A.I.R. pump bracket goes on the engines top left? My AIM depicts only a small block in UPC 6.
    Thanks! Dan
    EDIT: OK, I believe that I have found the correct depiction under the RPO L36 section showing the brace for the A.I.R. pump going to the stud which should be located on the top left of the water pump.
  • John C.
    • January 1, 2005
    • 616
    Re: 69 BB water pump bolt with stud
    Dan
    The stud was on the drivers side in 68 & 69.
    See the below link.
    https://www.forums.ncrs.org/showthread.php?t=76324
    John
