tachometers (C2) - NCRS Discussion Boards
tachometers (C2)
+ More Options
Posts
  • Mike S.
    • August 21, 2011
    • 57
    tachometers (C2)
    In 1963 were the tachometers different for the 300 hp and the 340 hp, appreciate the help I receive here. Mike
  • William C.
    • May 31, 1975
    • 6037
    Re: tachometers (C2)
    Different redlines so the face was changed giving them unique part numbers for the assembly.
    Bill Clupper #618
    • Mike S.
      • August 21, 2011
      • 57
      Thank you Bill, do you know what the difference was specifically?
        • 15706
        250/300 HP: 5000-5300, yellow; 5300-7000, red
        340/360 HP: 6300-6500, yellow; 6500-7000, red
        Depending on fading, the above colors have to be taken with a grain of salt, and early tachs used different shades than later tachs, so "red" may appear as orange or magenta.
        The 250/300 HP engines used the "base engine" cam that dated to '57, and the 340/360 HP engines used the Duntov mechanical lifter cam, which moved the torque and power peaks about a thousand revs up the scale and added about the same amount to the valve train limiting speed.
        • Mike S.
          • August 21, 2011
          • 57
          Thanks for the information. This confirms I was duped when I purchased my 63, but am a big boy, currently restoring to original. Mike
