VIN Resurection - NCRS Discussion Boards
VIN Resurection
  • Michael F.
    • November 17, 2011
    • 8
    VIN Resurection
    I have a 1982 coupe. I have the last nine digits of my VIN stamped on my engine and they match the "hidden" VIN derivitive on the frame. I want to find out the first 8 characters of the VIN. Is this hard to do or do I just follow the normal VIN code listed in the black book???
  • Arland D.
    Moderator
    • July 31, 1980
    • 427
    Re: VIN Resurection
    Hopefully, if you look at the A pillar through the windshield on the driver's side, you have a VIN tag with the entire number sequence.
    • Michael F.
      • November 17, 2011
      • 8
      Re: VIN Resurection
      Its not there.
      • Michael F.
        • November 17, 2011
        • 8
        Re: VIN Resurection
        I just need to know if "rebuilding" the VIN using the last 9 digits is a reasonable method of getting the correct number to register it. I already know its not stolen.
        • Arland D.
          Moderator
          • July 31, 1980
          • 427
          Re: VIN Resurection
          All but one of the characters is predictable based on the black book approach to VINs. One of the missing characters in your VIN is a generated 'check digit' that is calculated by a somewhat obscure formula that was written about in the Restorer magazine many years ago. If someone has it handy, it can be used to figure out the missing character or search on the restorer disc for the article by John Amgwert.
          • Tom R.
            • June 30, 1993
            • 4100
            Re: VIN Resurection
            What about the "vehicle certification label" that typically is glued to the driver's side door jamb? Not there?
            Tom Russo
            78 SA NCRS 5 Star Bowtie
            78 Pace Car L82 M21
            00 MY/TR/Conv
            • Tom H.
              • December 1, 1993
              • 3440
              Re: VIN Resurection
              Does this 82 have a title ?
              Tom Hendricks
              Proud Member NCRS #23758
              NCM Founding Member # 1143
              • Vinnie P.
                Editor NCRS Restorer Magazine
                • May 31, 1990
                • 1573
                Re: VIN Resurection
                Here's a pdf of the article, hope it helps
                • Tom H.
                  • December 1, 1993
                  • 3440
                  Re: VIN Resurection
                  Over my head.
                  Tom Hendricks
                  • Paul J.
                    • September 9, 2008
                    • 2091
                    Re: VIN Resurection
                    Michael,
                    Tom's asking if the title shows the VIN, which it should. What does it say? Is it a clear or salvage title?
                    Paul
                    • Michael F.
                      • November 17, 2011
                      • 8
                      Re: VIN Resurection
                      Thanks for all the support gentlemen. I will definetly use the formula to get the check digit correct and then register it properly. Sorry for the lack of response but due to my particular set of circumstances this is the only way I can "rebuild" the VIN.
                      Mike
                      • Peter M.
                        • April 8, 2007
                        • 570
                        Re: VIN Resurection
                        Over my head.
                        I'm with you, Tom
                        • Tom R.
                          • June 30, 1993
                          • 4100
                          Re: VIN Resurection
                          Originally posted by Michael Ferguson (54081)
                          Thanks for all the support gentlemen...this is the only way I can "rebuild" the VIN.
                          Well that's awfully, obviously suspicious!
                          Tom Russo
                          78 Pace Car L82 M21
                          00 MY/TR/Conv
                          • Paul J.
                            • September 9, 2008
                            • 2091
                            Re: VIN Resurection
                            Yeh? You notice he did'nt answer my question.
