67 a/c blows instruments fuse - NCRS Discussion Boards
  • Al M.
    • February 1, 2004
    • 64
    Whenever I turn my heater fan on or if I pull the a/c on knob, the fuse for aall of my gauges blows. I've replaced the in line capacitor under the hood at the blower and it has had no effect. I am also hearing a pop in the radio audio when I turn the fan switch. I couldn't find any threads on this. I can't believe I'm the only person with this problem. Any suggestions? Could my fan control switch be bad?
  • Joe R.
    • May 31, 2006
    • 1822
    Re: 67 a/c blows instruments fuse
    Al,
    I would suspect the blower. Disconnect it and see if the fuse holds. Has your blower been making unusual noises before the fuse problem?
    Joe
    • Al M.
      • February 1, 2004
      • 64
      no unusual noises. blows well in all speeds
        Al -
        Do you mean the fuse for all of the gauge illumination bulbs, or the fuse that powers the fuel and temp gauges?
        • Al M.
          • February 1, 2004
          • 64
          The fuse for the gas and temp gauges. not the bulbs.
            Al -
            There is no electrical relationship between the gage fuse circuit and either the blower or A/C circuits; you must have a pinched wire or a short somewhere.
            • Al M.
              • February 1, 2004
              • 64
              interesting. I'll start ohming out the harness. thanks for your help.
              • Gerard F.
                • June 30, 2004
                • 3805
                Al,
                The two circuits come together at the ignition switch on the supply side, and at the fuse box on the load side. I think the fuse box and connector would be a good place to start checking for a cross connect.
                Jerry Fuccillo
