1965 L-79 - NCRS Discussion Boards
1965 L-79
  • Michael S.
    • August 31, 1985
    • 75
    1965 L-79
    A friend has a '65 L-79, with the block stamped LU, what does that stand for?
    Thanks, Michael
  • Patrick B.
    • August 31, 1985
    • 1995
    Re: 1965 L-79
    What is the casting number and casting date of the block? What else is stamped on the block?
    • Michael J.
      • January 27, 2009
      • 7119
      Re: 1965 L-79
      The 3858180 block is LU, that is not an engine suffix, but I have no idea what it means. Perhaps Limited Use?
      • Patrick B.
        • August 31, 1985
        • 1995
        Re: 1965 L-79
        Does it have an engine plant stamping and a VIN stamping?
        • Clem Z.
          • January 1, 2006
          • 9427
          Re: 1965 L-79
          LU is a 69 427,435 HP
          • Michael J.
            • January 27, 2009
            • 7119
            Re: 1965 L-79
            I found a story on that other forum about how these 3858180 blocks were built in Tonawanda while the Flint plant was down for some reason during that time period in the sixties. They were designated "LU" for limited use in Corvettes, apparently many were used in other Chevys during those days, but only limited use in Corvettes. Maybe this is a rare block?
            This is story written there:
            1965
            Casting # Cubic Inches Description/Application
            3782870 327 250, 300, 350, 365 & 375 Horsepower
            3858180* 327 Limited Quantity of Units
            3855962 396 425 Horsepower
            * A limited number of these small block engines appear in 1965 Corvettes. Their casting origin was Tonawanda, New York; apparently shipped to the Flint, Michigan, V-8 engine plant for machining and assembly. Their usage is believed to be a substitution occurring during a foundry shutdown at Saginaw, MI.
            • Michael S.
              • August 31, 1985
              • 75
              Re: 1965 L-79
              Casting # 3858180, casting date A2164, heads 3795896, K-22, K-18, with a late vin #
              • Michael J.
                • January 27, 2009
                • 7119
                Re: 1965 L-79
                Yep, the limited use block.
                • Patrick B.
                  • August 31, 1985
                  • 1995
                  Re: 1965 L-79
                  I don't believe this engine came in a 65 Corvette. It's a 1964 model year Tonowanda block with heads consistent with a 1964 model year 250 hp 327. Incomplete dates are given for the heads, but I'll guess that they are K-22-63 indicating Tonowanda manufacture. If a few 180 blocks got in 65 Corvettes, what is the chance the blocks were already a year old rather than fresh? What are the complete stampings on the pad? Does it really have a VIN stamped on the pad. That would be unusual for a base 327 passenger car which is probably the source of this engine. A pad photo would help nail it down.
                  • Michael S.
                    • August 31, 1985
                    • 75
                    Re: 1965 L-79
                    Heads date 1963, vin # 19467S103780. The guy has had the car only about 6 months, the cast date on the block A is for what month?
                    • Patrick B.
                      • August 31, 1985
                      • 1995
                      Re: 1965 L-79
                      A is January. If the head is K-22-63 it is a Tonowanda head. If it is K-22-3 it is a Flint head. What exactly is stamped on the block? Certainly not that vin - which is also missing the year digit.
                      • Michael S.
                        • August 31, 1985
                        • 75
                        Re: 1965 L-79
                        Typo on the vin, it is 194675S103780, I'm having him get me what's stamped on the front pad, will get back to you.
                        • Michael S.
                          • August 31, 1985
                          • 75
                          Re: 1965 L-79
                          On the front pad is stamped TO 128S, nothing else. It has the correct Holley and intake.
                          • Clem Z.
                            • January 1, 2006
                            • 9427
                            Re: 1965 L-79
                            my book lists a "S" as 62-64,327,250 HP,PG,Pass car
