Looking for one of these impossible to find carburators. Any information on the where abouts would be Greatly appreciated. Whats on your shelf ???
68 Rochester 7028219 Q-jet
Re: 68 Rochester 7028219 Q-jet
Jeff,
You will need the date code also if you are going to have the car judged. I think that you need to be in that three month window before the car was made. There are carbs out there, and there are several carb dealers out there. The one I have worked with is in Middlesex, NJ. 732-356-433. be careful not to purchase a service replacement. The service replacement has a rectangular protrusion in the front of the carb.
Good luck with your search. Joe- Top
Good old Google
- Top
the one in you picture is not a service replacement.$(KGrHqIOKk!E58LD+sqzBOgK+!BNbQ~~60_3[1].jpg
this one is a service replacement notice the protrusion on the left front(driverside) it sisort of rectangular not square.- Top
joe
i see the protrusion in the photo and never seen one like that and know that mine don't have that feature either. Thanks for posting the impostor. The colors on this carb that i posted don't equal a 100% correct NCRS score do they ?- Top
that is the holder and locator for different external carb solenoids used for idle speed when the A/C is turned on for example.- Top
- Top
