Glove box light question - NCRS Discussion Boards
  • Wayne P.
    • January 23, 2008
    • 444
    I have the glove box out and noticed the switch ( glove box door ) I have seems to only be an off and on switch no light attached .
    ( orange wire with a black stripe. ) Does this mean my car did not come with the glove box light ? I had to cut the wire to remove the front face of the glove box as well.
    I believe this switch turned on the lower side interior lights same as when you open the doors.
    Sorry for the novice question.
    • 6954
    Re: Glove box light question
    Wayne, I had a recent post on the glove box shield and there is a pic that shows the correct switch. and the sheild that was on later cars. I believe 63 all had gove box lamps.
    • Wayne P.
      • January 23, 2008
      • 444
      Thanks Edward I have a 64. Will check out posts. thank you
      • William C.
        • May 31, 1975
        • 6037
        Same deal, all had a light.
        Bill Clupper #618
        • Doug L.
          • March 14, 2010
          • 442
          Take a look at LICorvette website, part no. 13-19a and click in the "detail". It shows how the wire with a hook mates with the housing and shield. I think opening the gloove box creates a ground for the bulb. Closing the glove box door interrupts the ground and extinguishes the lamp. There is no connection between the golve box light and the courtesy lights that actuate with doors opening.
          • Harry S.
            • July 31, 2002
            • 5338
            Doug, correct. When you open the glove box door. The black pin in the switch opens and a complete circuit is completed from the switch-glove box door frame to the Z bar and eventually back to the battery.
            When you close the door the black pin closes and disconnects the complete circuit. Saying that, the orange wire is always hot, so if you pull the glove box and don't disconnect the battery you have a hot wire. Either disconnect the battery or put electrical tape over the contact on the orange wire.
            • Wayne P.
              • January 23, 2008
              • 444
              Thank you for all the info and the safety tip on the hot wire.
