I am crawling around under the rear suspension checking for play, dry rotted bushings, and other stuff before I decide whether to restore or not.
It is becoming obvious that a previous owner did some rear suspension work since all the half shaft u-joints are the Federal Mogul 231 u joints, strut rods are later style, and rivets have been drilled out of the rotors.
I found something on the rear spring retainer that does not look right.
There appears to be an extra plate on top of the spring mounting plate where the 4 bolts go through to attach the spring to the rear cover of the differential. It is a very thick plate that also has a bolt going through it that is parallel to the spring. I searched for pics and I have not seen this plate on any other C3 rear suspension.
What is it? Why would it be there? Hmmm.
My camera is broken Or I would attempt to post a pic.
Thanks, Bill
Thanks, Bill
