67 repro tire judging. - NCRS Discussion Boards
  • Randy R.
    • March 1, 1983
    • 477
    How does the currently availble reproduction BF Goodrich WW tire compare to the Goodyear for judging purposes?
    Thank you,
    Randy
  • Keith B.
    • March 7, 2008
    • 928
    Re: 67 repro tire judging.
    it gets the standard deduct outlined in judging reference manual
    • Michael G.
      • November 12, 2008
      • 2158
      In case you don't have a reference manual, that's a 10% originality deduct ( you lose 3 of the 30 available points).
      Mike
      1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
      1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
      • Neal K.
        • October 31, 2007
        • 305
        Is there a reproduction tire that does not take a deduction.
        thanks
        Neal
        • Michael G.
          • November 12, 2008
          • 2158
          I don't think so, as there still are some other detectable differences on the tires I've seen.
          The 3 point deduct is designed to be very small, to insure that cars aren't being driven with dangerous 40 or 50 year old tires, just to avoid a large deduction.
          Take the 3 point deduct, find it somewhere else, its not worth the trouble.
          Mike
          • Neal K.
            • October 31, 2007
            • 305
            Who would you recommend as a good source for a reproduction redline tire for my 67?
            Neal
            • Herb P.
              • April 19, 2011
              • 37
              Try Coker Tires if you want to go radial. I used them for my '67 and they look great and handle well. Not sure about their redline bias ply tires
              • Terry B.
                • August 31, 1999
                • 607
                Unless there has been a significant change in their production, Coker does not have the correct tire tread count. I found that Kelsey Tire http://www.kelseytire.com/home.html has the best reproduction tires overal in my research for '68's. I would think that would carryover to '67's too. Be sure to read your original tire requirements in the '67 TJM. No need to make an expensive mistake.
                Terry Buchanan
                Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
                Corvettes Owned:
                1977 Coupe
                1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
                2003 Electron Blue Coupe
                2019 Torch Red Grand Sport Coupe
                • Steve B.
                  • March 1, 2002
                  • 1195
                  I think that the reproduction goodyear WW tire is closer to OEM than the BFG tire. All the repop BFGs do not have the 660 after the silvertown like originals do. If you want a redline tire then the coker firestone supersport is the way to go. They are still easy to detect from OEM but I truly believe that Goodyear never made a redline tire in 67 inspite of what the manual says.
