"pre filling" oil filter - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1283
    I'm going through the January 2012 edition of Corvette Magazine. I come across page 82 and I see a picture that looks like they are "pre filling" the filter.
    I've never seen this! Has anyone done this with the filter.
    Jerry
  • Keith B.
    • March 7, 2008
    • 928
    Re: "pre filling" oil filter
    that's how I was taught
      • 43219
      Jerry
      Jerry-----
      I've done it this way for years. Is it absolutely necessary? No. Is it advisable? Yes.
      There are some applications, of course, which because of oil filter orientation cannot be pre-filled. LT5 is one of them.
        • 15599
        I am not sure it makes much difference -- that said I have always pre-filled the filter, even on some cars where the filter was at an angle on the side of the cylinder case I filled it as much as I could. Why would I do that if it makes little difference? 1) it is simple and easy to do. 2) It can't hurt.
        If you want to have some fun and waste a lot of time go to www.bobistheoilguy.com (known as bitog) and see the discussion raging over there. I would bet it (that discussion) has been going on for decades over there.
          • 43219
          Terry-----
          Pre-filling the oil filter will reduce the amount of time it takes for oil pressure to come up on start-up after a filter change. The difference is probably a second or less but I think it's worthwhile.
          • Jim T.
            • March 1, 1993
            • 5351
            I also have prefilled the new oil filter for years before installing it. I also punch a hole in bottom of the filter and let it drain into oil pan with the drainage from the oil pan before removing the filter.
            • Tom P.
              • April 1, 1980
              • 1814
              I've been doing it for almost 50yrs.
              • Tom H.
                • December 1, 1993
                • 3440
                Never done it any other way !!!
                Tom Hendricks
                Proud Member NCRS #23758
                NCM Founding Member # 1143
                • Edward B.
                  • January 1, 1988
                  • 537
                  I have always prefilled canister type oil filters in cars and boats when their vertical orientation allows same without spillage - it does provide for a quicker showing of oil pressure upon restart. Openining the new oil container also provides a source of clean oil with which to lubricate the o-ring on the filter before installation.
                  • Chris S.
                    • January 1, 2000
                    • 1067
                    I always do - no matter what filter I install on what car
                    the upside down ones - you cant
                    It helps ensure the bearings rec oil right away on start up
                    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
                    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
                    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
                    1957 Corvette - FI 3 sp - Black and Silver
                    • Paul J.
                      • September 9, 2008
                      • 2091
                      Right, which means that it has virtually no practical impact.
                      • Joe R.
                        • July 31, 1976
                        • 4550
                        Well it is recommended on Ford and Cummins diesels. Don't know why but it takes no longer for a diesel to fill the filter than it does a gas burner.
                        The time theory is then thrown out the window!
                        Always the old saying, " Better to be safe than Sorry" comes into play here!
                        JR
                        • Gerard Q.
                          • February 1, 2000
                          • 284
                          In the 44 years I've been changing my own oil I've never done it....never had an engine related problem. I do lubricate the oil filter gasket.
                          • Michael H.
                            • January 29, 2008
                            • 7477
                            I agree. Pre filling the filter can't hurt but it's not really necessary.
                            • Dick W.
                              • 10483
                              JR
                              No workee on newer Ford diesels. 6.0 and newer are mounted on top of the engine and drain back all the time
                              Dick Whittington
