1959 frame specifications - NCRS Discussion Boards
  • Charles K.
    • May 31, 1989
    • 22
    I have a 1959 which was apparently hit in the left front side. I determined that the frame is bent slightly and I can't align the front end (camber on the right tire). Does anyone have or can tell me where I can get frame specifications or measurements. I have removed the body and have a frame specialist lined up to pick up my rolling chassis(?).
  • Gary C.
    Administrator
    • October 1, 1982
    • 17916
    Re: 1959 frame specifications
    Chuck, '58 frame specs om a previous post. Gary....
    https://www.forums.ncrs.org/attachme...3&d=1239664143
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Jerry W.
      • January 27, 2009
      • 588
      THE ATTACHED LINK MAY BE OF INTEREST OR HELP WITH THE ALIGNMENT
      http://www.vetteweb.com/tech/vemp_0206_aligning_solid_axle_chevrolet_corvette/index.html
      • Bruce B.
        • May 31, 1996
        • 2930
        Frame specs are in the ST-12 and possibly in the front of each AIM.
        • Charles K.
          • May 31, 1989
          • 22
          THANK YOU !! You guys are great. The specs are just what I needed and the article explaining the process was terrifc. What a wonderful resource (NCRS and Technical Board) is. I would have never found that article on my own. Thank again for the help.
          • Jerry W.
            • January 27, 2009
            • 588
            Replaced left front frame horn to ST-12 frame specs on 62 vette....body man double checked chassis for squareness B4 proceding...attached is his sketch and dimensions...hope it helps someone here.
