54 wiring question - NCRS Discussion Boards
54 wiring question
  • Guy M.
    • November 1, 1993
    • 500
    54 wiring question
    On my new harness there is a 12 gage black with white tracer coming out right next to the instument mount ground. It has an insertion connector. Anybody know what it connect to? I cant find it on the wiring diagram. Thanks as usual
  • Chris S.
    • January 1, 2000
    • 1069
    Re: 54 wiring question
    on the drivers side....
    there are two wires going to the courtsey switch
    There are two wires going to the courtsey lamp
    there is the ground to the metal for the instruments
    there are two wires for the brake light switch
    there is a pink and a red that go to the junction block on the firewall
    there is a bunch that go to the light switch.
    there is a several that go up to the steering column for the horn, turn signals and brake lights.
    I think the black is the horn wire....
    i can look tonight....
    do you have a Lectric Limited diagram
    it is pretty good - except for the radio, heater,
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • Guy M.
      • November 1, 1993
      • 500
      Yeah, its a LL harness. I have the rest of it figured out except for this Ground, it exits the harness right next to the instument panel ground. I dont think it goes to the light switch. The turn signal leads have been accounted for. This plugs into something. I appreciate your effort!!! The diagram isnt showing a 12 gage black and white tracer wire going anywhere near.
      • Chris S.
        • January 1, 2000
        • 1069
        can you shoot me a pic of the terminal end?
        all wires up thru the column accounted for?
        wires plugged in going to the rear of the car? - behind the DS kick panel
        there is a bunch of wires to the headlight switch
        sorry - I forgot to look last night
        • Guy M.
          • November 1, 1993
          • 500
          I figured it out last nite, its the ground to the courtsey light switch. What threw me was the right side has a 10 gage wire and the left side has a 14 gage wire. It didnt help that the connectors are too small for original screws. I guess I can drill them, I hate to already splice a new harness with the right size connector. Sorry if I caused any inconvienance. Thanks again
          • Chris S.
            • January 1, 2000
            • 1069
            depends on if its an early 54 or late
            the late 54's - the courtsey light wire - "plugs" into the back of the switch
            the 53's and early 54's the ground was sandwiched between the body and the switch
            they redesigned the switch
            alot of guys will attach them to the back of the screw with a body nut so the switch sits flush.
            • Guy M.
              • November 1, 1993
              • 500
              Thanks Chris, my car is right in the middle of the run. Can I just attach the wire to the screw and double nut it? Im not familiar with a "body nut" It would seem the ground to the tail lights would have the issue.
              • Lynn L.
                1953-55 Team Leader
                • February 1, 2000
                • 162
                I double nutted my courtesy grounds, works well, hard place to reach, I place a magnet on the courtesy switch plate,then the nut will magnetically attach to mt bolts for easier placement.
                • Guy M.
                  • November 1, 1993
                  • 500
                  Thanks Lynn, thats what Ill do!
