Are there any major differences in the 64-67 Corvette power brake boosters that I see on line, other than the partial part number stamped on the tab? They all seem to look the same, with the riveted bracket & no Delco stamping on the case. Most I assume are made off shore??? Prices range from ~ $70 to over $400. I'd like to replace my 66 original, it is a little too pitted to be replated. Thanks!
Power brake booster, advice.
Re: Power brake booster, advice.
Joe, I guess the $75.00 PB booster with free shipping, will work for me just fine! Thanks, Glen.- Top
While the front and rear shells may be the same as 64-66, I believe there are some internal differences for 67. I don't remember what the differences are though. Seems like I remember that some of the internal components had a unique part number for 67?- Top
Glen,
The booster-to-master cylinder pushrod (which is part of the booster assembly) is the "long" version on the '67 booster; '67 was the only year that used exactly the same master cylinder (5455509/DC) for both manual and power brakes, and that master cylinder had the "deep" hole in the rear piston due to the manual brake application. '64-'66 boosters had the "short" pushrod, as their master cylinders were unique for power brakes and had the "shallow" hole in the piston.
There may have been other internal changes in the '67 booster, but I've never had one apart.- Top
Michael -
Yes, they were exactly the same with the exception that the 67 Manual had a cast number of 5455509 stamped DC and the 67 Power had a cast number of 5480346 stamped PG. Also you might find that the manual had a smaller piston and the power had a 1 1/8" piston.
Doesn't the 67 Judging Manual reflect this difference?????
JR- Top
John,
JR
Are you sure about that? I thought 67 with with and without power brakes were th same with a 1" bore. Only 67 with heavy duty brakes used a different master cyl. with a 1 1/8" bore.- Top
The 68 model was the year that began using different cyl's for standard and power brakes.- Top
