june 68 327 oil pan - NCRS Discussion Boards
june 68 327 oil pan
  • Jeff P.
    • October 21, 2011
    • 287
    june 68 327 oil pan
    Hi All,
    looking for code stampings on a 1968 june small block oil pan ? also what is the correct size of the drain plug hex? was this a 5 or 6 quart oil pan for this 327 / 350 hp. any unique markings for this large journel oil pan ?
    • 43248
    Re: june 68 327 oil pan
    Originally posted by Jeff Piekutowski (53984)
    Hi All,
    Jeff------
    There were no stamped codes that I'm aware of on these pans. However, I don't recall ever studying the rail surfaces so it's possible there was one there.
    1967 pans all used the large hex and 1969 Corvettes all used the small (9/16" across-the-flats) drain plug with flanged head. I believe that all 1968 used the small hex but it's possible that early used the large.
    ALL 1968 small block oil pans were of the "5 quart" variety; no exceptions.
