96 Alternator - NCRS Discussion Boards
96 Alternator
  • Nick B.
    • April 30, 2002
    • 27
    96 Alternator
    Hi everyone,
    I'm trying to find out where I can get a correct dated alternator, restored or otherwise, for my 96!!THANKS AS ALWAYS!!
  • Tom H.
    • December 1, 1993
    • 3440
    Re: 96 Alternator
    Hi Nick ! Do you have your original now that has failed, or do you need a complete unit ?
    I guess my question is, what is on your car now ? A failed original or a replacement ?
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
      • 43221
      Re: 96 Alternator
      Nick and Tom------
      I believe the original alternator part number will be 10480202.
      • Pat F.
        • April 1, 1981
        • 853
        Re: 96 Alternator
        Gentlemen, attached is a photo of the original alternator off of my 1995 LT1. It shows part number 10480139. It has a date stamp of 72794. This is July 27, 1994. My build date is August 4, 1994. The second day of 1995 Production.
        The NCRS Judging Manual for 1994-96 shows a part number for the LT1 for 1995 and 1996 as 10488139. Seems to be a differance.
        Also the Judging Manual shows part number 1040200 for 1995 and 1996 for the LT1.
        Just my two cents in trying to help.
        PAT, Central New Jersey and Florida Chapters
          • 43221
          Re: 96 Alternator
          Charlie-----
          I think the JG has it wrong. Early 1995 used GM #10480139. Your car is about as early as a 1995 could be so you have the correct alternator.
          Late 1995 as well as all 1996 LT1 were supposed to have used GM #10480202. I have no idea when the change-over occurred.
          Both alternators are 140 amp units.
          • Pat F.
            • April 1, 1981
            • 853
            Re: 96 Alternator
            Joe, I agree 100%.
            Thanks again, maybe I will start another survey to find out when the change over took place. I said I would never do another one, but .
            • Nick B.
              • April 30, 2002
              • 27
              Re: 96 Alternator
              Hi Tom,
              I'm thinking that it's a replacement since there are no part or date #s visible on the casing!!My SYS warning light flashed a few times at idle yesterday,so I'm thinking alt.??Nice to here from you again and THANKS!!
              • Tom H.
                • December 1, 1993
                • 3440
                Re: 96 Alternator
                Originally posted by Nick Barrasso (37869)
                Hi Tom,
                Not sure I'd jump right to the alternator on an SYS flash. Was the battery drained or has the car been sitting for a long period ??
                Tom Hendricks
                • Tom H.
                  • December 1, 1993
                  • 3440
                  Re: 96 Alternator
                  I just examined 2 96 LT1's. I was unable to locate a part number on the alternator of either. One is a known original, and I assume the other was too. No date or part number visible.
                  Tom Hendricks
                  • Nick B.
                    • April 30, 2002
                    • 27
                    Re: 96 Alternator
                    OK Tom,so what's a guy supposed to do when you get your car judged and they ding you on an alt. with no markings, which is exactly what happened to me,and that was at the chapter level,just think of what will happen at a Regional or National!!Back to basics I guess.The car has sat for a couple of weeks or so,so do you think I should just put on the battery minder and see if it goes away.And the original question was where (or how)do I find an original alt.if need be???Sure hope I can meet you one of these days and buy you a beer or something!!Thanks!!
                    • Nick B.
                      • April 30, 2002
                      • 27
                      Re: 96 Alternator
                      Thanks for that AWESOME picture Charlie!!I sure wish mine looked like that.The more info. I get,the more confusing it is,as by Toms' reply,he has 2 original with NO marking on them at all!!
                      • Pat M.
                        • April 1, 2006
                        • 1575
                        Re: 96 Alternator
                        Great advice. My 96 has flashed the SYS code about three times in its life, and every time it was a bad/low battery.
                        • Dick W.
                          • 10483
                          Re: 96 Alternator
                          I can't spell C-4, but if you disagree with the judging guide, I would contact the Team Leader, his contact info can be found at the top of this forum under contacts.
                          Dick Whittington
                          • Tom H.
                            • December 1, 1993
                            • 3440
                            Re: 96 Alternator
                            I haven't seen the judging guide for the C4's. Where does it specify the date and part number is located ? Is there more than one location listed ? I used a mirror and examined 2 units pretty closely and could not find anything.
                            Tom Hendricks
                            • Nick B.
                              • April 30, 2002
                              • 27
                              Re: 96 Alternator
                              I haven't seen the judging guide for the C4's. Where does it specify the date and part number is located ? Are there more than one location listed ? I used a mirror and examined 2 units pretty closely and could not find anything.
                              The numbers are right on top easily visible from the picture that Charlie Fullam sent.
