Midyear small block Carburetor to Intake Manifold studs - Are these originals? - NCRS Discussion Boards
    • 43222
    Re: Midyear small block Carburetor to Intake Manifold studs - Are these originals?
    Originally posted by Scott Smith (50839)
    Tim,
    The AIMs call out the same GM 120368 part number for the carburetor nut from 1963 through at least 1969. In the '67 AIM, this same Nut part number is also called out for the unidentified fan clutch to fan blade studs, and also secures the hose clip to the front of the A6 compressor.
    FWIW, AMK shows this part number as being 5/16-24, Grade 5, 1/2" across the flats, .27 thick. Their photo shows what appears to be a standard height hex nut.
    Edit: just saw Joe's post, looks like AMK has this one right.
    Scott-----
    By the way, GM specifications for most nuts have an allowable range for the various dimensions. So, I would not expect every GM #120368 nut to measure exactly 0.270" thick.
    • Scott S.
      • September 11, 2009
      • 1961
      Originally posted by David Liukkonen (3775)
      Scott,
      I have collected many original carb studs from Chevrolet and Corvette intakes over the past 30+ years but mainly in the 1980's. All I could EASILY find are the studs pictured below.
      Early 1963 300 HP C.I. intake, cast. # 3799349 dated K122 (Nov. 12, 1962),
      measured 1.77" OAL, 0.50" long coarse threads, 0.97" long fine threads, "dimple" on bottom end.
      Early 1966 B.B. C.I. intake, cast. # 3866948 dated I245 (Sept. 24, 1965),
      measured 1.31" OAL, 0.45" long coarse threads, 0.54" long fine threads, "dimple" on top end.
      Dave
      Thanks for the pictures Dave,
      It looks like they made these carburetor studs both ways, in which case the 'dimple' or lack thereof on the nut-end of the stud should not be a determining factor regarding originality.
      • Gary S.
        Super Moderator
        • February 1, 1984
        • 457
        #18
        If you have a 67 L79, you are safe with those studs from what I have seen over the years. I have had lots of 67's and have 3 now including a tri-power and L79. The carb studs are the same on both cars, so appear to be standard for a Holley carb. Both 1 5/16 long and a hollowed end on the bottom and dimple end on the topside.
        Avatar--My first ever vette, owned 3X since 1977, restored 1993-2024. Top Flight Award 9/14/24
        • Scott S.
          • 1961
          #19
          Gary,
          Thank you very much for the info and pictures,
          Scott
          • David L.
            • July 31, 1980
            • 3310
            #20
            Scott,
            While looking for some other parts I came across the following original carb to manifold studs:
            Early 1969 3927184 CI intake dated G98 (July 9, 1968)
            measured 1.33" OAL, 0.45" long coarse threads. 0.67" long fine threads, no dimple
            1958 3746829 C.I. intake dated E 28 8 (May 28, 1958),
            measured 1.50"-1.56" OAL, 0.50" coarse threads, 0.84" fine threads, no dimple
            Dave
            • Scott S.
              • 1961
              #21
              Dave,
              Thanks very much for remembering the Thread and taking time to post the measurements!
              • David L.
                • July 31, 1980
                • 3310
                #22
                Scott,
                As usual I found some more of my intake studs while looking for other parts. Photos are in the link below.
                3866948 C.I. BB (Holley), I245 (Sept. 24, 1965)
                O.L. = 1.32", fine thread length = 0.60"+/-, coarse thread length = 0.48"+/-
                3872783 C.I. SB (Holley) B46 (Feb. 4, 1966)
                O.L. = 1.52", fine = 0.80"+/-, coarse = 0.50"+/-
                3875952 C.I. SB (Rochester) E106 (May 10, 1966)
                O.L. = 1.54", fine = 0.88"+/-, 0.54"+/-
                N.O.S. GM # 382919
                O.L. = 1.25", fine = 0.52"+/-, coarse = 0.52"+/-
                Dave
                Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.
