C2 1966 3811 Carb vs. 1967 3370 Holley - NCRS Discussion Boards
  • Tom D.
    • September 30, 1981
    • 2133
    I SHOULD HAVE POSTED 1967 3811 ABOVE.
    I found these words from Bill Stephenson, posted back in 2006.
    "In my opinion... the 67 carb is not as good as the 66. I believe that the 67 has no external float-bowl adjustment. You have to take the bowl off and bend the arm. 66 had adjustable floats. I have always thought that it was a cheaper carb, not better. Others more knowledgeable than me may feel differently............Bill S."
    Are there other differences? 1966 390 HP to 1967 390 HP (L36, non-A.I.R.)?
    Thanks!
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
  • Pancho T.
    • July 31, 1993
    • 238
    Re: C2 1966 3811 Carb vs. 1967 3370 Holley
    Thanks!
    Not sure but I have a couple of both.I will take a look this weekend
    • Wayne W.
      • April 30, 1982
      • 3605
      The 67 would be the 3811, and 3810, I believe 66 would be 3367. other than the obvious difference in needle valves, I think jetting in the metering block is only significant difference.
      • William C.
        • May 31, 1975
        • 6037
        both are 585 cfm rated Holley single feed carbs, but as smog was starting to get more attention the metering block jetting will likely be different.
        Bill Clupper #618
        • Gerard F.
          • June 30, 2004
          • 3805
          Thanks!
          Tom,
          Other than the float adjustment issue, I think they are the same. Same metering block, jets, same secondary metering plate.
          However they have a different throttle body part number. I think it has to do with the levers and attachments to the throttle body. They changed something there for 67, but not operational.
          Jerry Fuccillo
          • Tom D.
            • 2133
            Thanks all!
            Michigan Chapter
            Tom Dingman
            • Anthony P.
              • October 26, 2011
              • 199
              Ok a bit off the subject as to which carb is better, but I have a 66 390 horse with carb list #3606 what is that now I'm confused.
              • Pancho T.
                • July 31, 1993
                • 238
                A #3606 is for a 390hp with air injection reactor (California smog)
                • Anthony P.
                  • October 26, 2011
                  • 199
                  Ok plot thickens, MI car sold out of a MI Dealer (K-19) MI car?
                  • Tom D.
                    • 2133
                    Perhaps the smog control parts came as an option?
                    Michigan Chapter
                    Tom Dingman
                    • Ronald L.
                      • October 18, 2009
                      • 3248
                      Does it have all the other K19 parts? Or just the carb???
                      • Anthony P.
                        • October 26, 2011
                        • 199
                        Just the carb, when I bought it in 1974, one of the past owners removed the exhaust manifolds and installed those nasty black headers. so I can't tell by the exhaust manifolds, no pump or hoses, the air cleaner looks original, with the silk screening, and only has one tube on the bottom section for the valve cover vent. No clue what it came with can't find any history from the 8 years from birth till I bought it.
                        Sorry for blabering!!
                        • Ronald L.
                          • October 18, 2009
                          • 3248
                          I think I emailed you a couple of weeks ago about this car!
                          OK, IMHO I seriously doubt a MI car would get smog. What I can tell you is that the carb you have on the car was the service carb in the mid 70's and I think if you dig deep enough and or Joe Lucia chimes in, that will be seconded within the archives.
                          Next 3370's - real - not faked up ones are hard a hens teeth to find, and were in the mid 70's when most people would have settled for a holley double pumper, but your Prev Owner went to the dealer and bought was was the service part. That's actually a good thing.
                          Your air cleaner with printing on it is a service part, and the base just might be the real deal too.
                          Did you ever get your NCRS shipping report?
                          • Anthony P.
                            • October 26, 2011
                            • 199
                            Ron yes you did email but I lost all emails when switching to a new lap top! Shipping report came back and dealer is still in business but no help might have to show up in person in the spring! Please PM or email and we can continue I do need any help to sort this out
                            Thanks Tony
                            • Gene M.
                              • April 1, 1985
                              • 4232
                              Is there not a different build code on the deck for a Ca emission option?
