Holly Carb on '66 Roadster - NCRS Discussion Boards
  • Edward S.
    • April 1, 1998
    • 36
    Just finished rebuilding the Holly carb on my '66 Roadster. Noticed some "sweating" coming from a dime sized plug just above the fuel inlet on the driver's side. There is a corresponding plug on the rear bowl too. The rear one is ok. I checked around and none of the folks I spoke with have seen this condition before. Has anyone seen this occur. If so, how can it be resolved?
  • William C.
    • May 31, 1975
    • 6037
    Re: Holly Carb on '66 Roadster
    What engine or better yet, what carb number?
    Bill Clupper #618
    • Edward S.
      • April 1, 1998
      • 36
      Bill, it is a 327/300. Unfortunately, i do not have the number with me.
      • William C.
        • May 31, 1975
        • 6037
        Essentially you have three choices that I am aware of, pull the float bowl off and re-stake the crimp that closes off the leak path from the disk that is in place to seal off the machining access hole in the bowl, apply a clear epoxy and see if that will seal the leak, or replace the bowl.
        Bill Clupper #618
        • Clem Z.
          • January 1, 2006
          • 9427
          there is a "O" ring under that spun in plug and carb cleaner will destroy the "O" ring. use clear fuel proof model airplane "dope" to seal this plug and it will be hard to detect because it is clear.
          • Edward S.
            • April 1, 1998
            • 36
            Thanks, Guys. I will seal it and see how it does. I shouldn't be surprised that our members would know of the condition and how to resolve it. Thanks.
            Ed S
