A.I.R. pipe finish - NCRS Discussion Boards
A.I.R. pipe finish
  • Jeff S.
    • July 31, 1984
    • 384
    A.I.R. pipe finish
    What is the correct finish for A.I.R. pipes/tubes? My TIM/JG (4th edition) says "brown in color" for 327 & "plated brown ... tubes are not painted" for 427. Dobbins says "black oxide". Looking for something to use to approximate the original color & gloss level.
    Thanks in advance.
    • 43211
    Re: A.I.R. pipe finish
    Thanks in advance.
    Jeff-----
    I think the tubes were a finish called black zinc. This finish varies somewhat from a very dark brown, to a black.
    • Mark G.
      • March 1, 2001
      • 227
      Jeff -
      This is what I have about the finish. The manufacturing process, thickness of coating, and engine heat after installation varies the original color. Take pictures of installed pipes to compare and check reproduction parts.
      Mark
      • Jeff A.
        • January 1, 2000
        • 312
        Jeff-----
        Yes - Black zinc. With heat and time they changed to a greenish brown.
        My Cars
