1962 radio ground - NCRS Discussion Boards
1962 radio ground
  • Jeremy H.
    • January 1, 1999
    • 260
    1962 radio ground
    Can someone send me a pic of the routing through the firewall of the radio ground wire for a '62 Fuelie? I don't seem to have a hole for a grommet as shown in the AIM.
    Jeremy Hedges
    #31711
  • Christopher R.
    • March 31, 1975
    • 1599
    Re: 1962 radio ground
    Look in the AIM. In the options section. At the back of the book. I think the wire goes through that firewall hole where the ignition harness goes. But the AIM should show it.
    • Philip P.
      • February 28, 2011
      • 558
      Here is what it looks like in the 1980 AIM
      Phil
      • Jeremy H.
        • January 1, 1999
        • 260
        I have seen this page in the AIM, but I have two 62's here and neither of them have this hole in the firewall for this ground wire thru a grommet. They are not radio delete cars, so I would hate to drill a hole for this if there is another option. Is this the same hole as the wiring harness goes thru?
        Jeremy Hedges
        #31711
        • Christopher R.
          • March 31, 1975
          • 1599
          Yes, don't drill a hole. The wire goes through an existing hole. I believe that hole is the one the ignition wiring harness goes through. There's no other holes in the firewall in that area. There is no difference between the fuelie and the other 3 models. I thought the AIM showed it better.
