Rear leaf spring installation - NCRS Discussion Boards
  • Jim M.
    • August 31, 1986
    • 50
    After three or four attempts to hoist up a rear leaf spring with one hand while juggling the retainer plate and bolts with the other, I made a short loop of rope and looped it over the crossmember the pumpkin bolts to. Inserted flat upper leafs into loop of rope at one side and got it done. Worked for me.
  • Timothy B.
    • April 30, 1983
    • 5203
    Re: Rear leaf spring installation
    Jim,
    Make sure you put the weight of the car back on the tires/ground BEFORE you tighten the four 9/16 bolts at the retainer. You will put the spring in a bind and crack the cover if not.
    • Jim T.
      • March 1, 1993
      • 5351
      Originally posted by Timothy Barbieri (6542)
      Jim,
      Tim do you have the information on what the torque specifications are for the bolts when the weight is on the spring?
      • Jim M.
        • August 31, 1986
        • 50
        GM manual calls for 70 lb. ft.
