Guide headlights low beam vs. high beam - NCRS Discussion Boards
  • Kenneth H.
    • October 27, 2008
    • 500
    This may be elementary to most of you here, but I'm trying to figure out what I have. They are two original T-3 headlights with the vertical lines in the triangle and two connection posts in the rear. I was told that they were high beams, but I can't figure out how to comfirm this. They're for my '70 LT1. I have a feeling that there's an easy answer, but I don't know what it is.
    Any help would be appreciated.
    Thanks.
    • 43245
    Re: Guide headlights low beam vs. high beam
    Thanks.
    Ken-----
    2 blade terminals = high beam
    3 blade terminals = low beam
    Why? Well, it's because the high beam is either on or off. The low beam sealed beams have one power configuration for when just low beams are activated and another power configuration for when high beams are activated.
    • Kenneth H.
      • October 27, 2008
      • 500
      Joe, thanks for the quick response. Now I get it. So I've got my high beams and if I want to get low beams I should be looking for 3 blade T-3s. That's easy.
      Thanks.
        • 43245
        Thanks.
        Ken------
        Good high beam units are easier to find than good low beam units. That's because the high beams are rarely used so the sealed beams are practically "immortal". The low beams, on the other hand, see a LOT of use. So, the low beam power configuration of the used low beam units might have burned out and, thus, have been replaced with a non-GUIDE unit at some point(s) in the past.
        • Kenneth H.
          • October 27, 2008
          • 500
          Joe, I know what you mean. I just checked mine and both low beams, as well as one high beam were replaced sometime in the past with non-guide units. I guess I'l need to start looking for the guide low beam 3 blade lights.
          I'm sure I'll track them down eventually. I looked for a correct date coded Holley list 4555 carb for 3 years before I found one, and it took me 2 years to find a correct date coded 1100884 alternator, so I guess they'll turn up eventually, and I'm sure I'll overpay for them.
          Thanks.
            • 11659
            Ken,
            They're not that difficult to find, and if you really want there are repros of those lights.
            Patrick
            • D S.
              • March 1, 2005
              • 1551
              I routinely find those T-3s for 1968-1971 cars at swap meets for $5-$10 each. If you see a grayish discoloration at the tops of the lamps they are either burned out or very near burned out.
              Another source is old salvage yards in smaller towns.
              • Kenneth H.
                • October 27, 2008
                • 500
                Patrick, Scott,
                Thanks for the input. I'll keep my eyes open for them. The headlights currently installed work fine (although I rarely drive at night). I'm looking for originals for when the time comes that I get the LT1 judged.
                Thanks.
                • Reba W.
                  • 938
                  We just sold a box lot of both high and low beams in an auction this past weekend. My car is a 1972 or I would have bought them.
