update and pictures on dads 67 black coupe - NCRS Discussion Boards
  • Keith B.
    • March 7, 2008
    • 928
    got most of the paint striped off and found some old repair jobs then we got it completely striped down and only ran into a few rust problems. then we pulled the frame and found some odd things so here are the pictures
    and now for rust repair
    this is under the driver side rocker channel by the last body mount
    these are the trailing arms
    and has anyone seen this on the rear spring bolt hanger
    the frame is ready to go to the sand blaster then off to powder-coat
  • Keith B.
    • March 7, 2008
    • 928
    Re: udpate and pictures on dads 67 black coupe
    also what year trailing arms interchange. there is a mid 70's shark in a scrap yard that still has them.
    • Paul J.
      • September 9, 2008
      • 2091
      Keith, you might be better off buying new reproductions.
      Paul
      • Russ S.
        • April 30, 1982
        • 2162
        What you are pointing to is a nut plate for the rear sway bar link.
          ...with both bolts snapped off.
          • Keith B.
            • March 7, 2008
            • 928
            both arms are like this. the car still has the 7 leaf rear spring. the the sway bar is missing.
