Motor oil - NCRS Discussion Boards
Motor oil
  • W K.
    • December 16, 2009
    • 61
    Motor oil
    Looking for help picking a motor oil to run in my original L79 motor. I just finished the first 500 miles after a rebuilt. Weight, conventional, synthetic? Any help is appreciated. Speed shops are trying to sell me 20-50, I think it is to heavy.
  • Donald H.
    • November 2, 2009
    • 2580
    Re: Motor oil
    Look Here, there's a good article from Duke William about oil for vintage engines
    https://www.forums.ncrs.org/showthre...&highlight=oil
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
    • Paul H.
      • September 30, 2000
      • 683
      Re: Motor oil
      I have been running Shell Rotella 15W40 in all of my old Corvettes for many years with no issues.
      Oil is one subject you will never get a consensus on. Duke's article is very informative.
      • Jim T.
        • March 1, 1993
        • 5351
        Re: Motor oil
        I am also using Shell Rotella 15W40 in my original owner 68 L79. Engine has not been rebuilt. When I started using Rotella I could get 10W30, don't see it on the shelves anymore where I shop.
        • Stuart F.
          • August 31, 1996
          • 4676
          Re: Motor oil
          I too use the 15wx40 Rotella T in my 63 L-76 SHP. I wanted to go to the 10wx30 for the cool months and had heard "Advance Auto Parts" would/did order it for some of the other TDB users. Ihave a store a couple blocks from my house so I stopped in to check, and low and behold, they had as much 10wx30 on the shelf as 15wx40. So, I picked up to gallon jugs for my next oil change.
          For me, the heavier oil was running a bit too high on pressure and I was experiencing a few minor leaks. I hope the lighter weight oil may work out better - at least in the cooler months down here in Florida.
          Stu Fox
          • Michael W.
            • April 1, 1997
            • 4290
            Re: Motor oil
            No need to go to a speed shop 'boutique' to buy oil. Walmart carries Rotella.
              • 15673
              Re: Motor oil
              What's with this Rotella obsession? It's far from being the only game in town.
              • Michael W.
                • April 1, 1997
                • 4290
                Re: Motor oil
                It's the only brand that many of us can find without a special order.
                  • 15673
                  Re: Motor oil
                  Most auto parts stores I go to stock Delo, Delvac, and Rotella, plus a house brand... same with Walmart, but Costco only carries Delo.
                  I just buy the least expensive CJ-4 I can conveniently find.
                  • Richard F.
                    • May 31, 1986
                    • 193
                    Re: Motor oil
                    Just the other day I encountered for the first time, and bought, a gallon of Valvoline Cummins-approved synthetic that is CI-4 and CI-4 Plus rated and is 5W-40. Though it was espensive at about $30 I bought it because I was remembering (maybe in error) that CI-4 has a more reliable content of zinc than CJ-4. I also thought that maybe the 5W would be easier on a cold, cranking motor. Thoughts?
                    • W K.
                      • December 16, 2009
                      • 61
                      Re: Motor oil
                      Thanks for all of the reply's. Like Paul my oil presure is a kind of high, maybe still breakin in. I will try the 10-30, Retolla seems very popular they should pay you royalties
                      • Michael J.
                        • January 27, 2009
                        • 7122
                        Re: Motor oil
                        Ditto, right now Motorcraft is the cheapest.
                        • Kenneth T.
                          • March 23, 2008
                          • 631
                          Re: Motor oil
                          Walmart CJ4 all U need 2 do. Many Duke posts on this.
                          • W K.
                            • December 16, 2009
                            • 61
                            Re: Motor oil
                            I ending up with Joe Gibbs Driven 10-30w conventional. Not the cheapest, but worth it to me, $9 a quart at local speed shop. Still plenty of oil presure, 40-50 psi at idle. I only have around 400 miles on a rebuilt engine.
                            • Jerry K.
                              • December 1, 1981
                              • 93
                              Re: Motor oil
                              I use Brad Penn 30 weight in my 62 for under $6.00 a qt. No problems with oil pressure on my P.V. this summer.
