Need a little help on a turn signal problem. Left and right turn signals just stopped working. Mechanically the handle seems to be working, feel wise. I hope it’s not that turn signal switch in the steering wheel column. Have read some of the older threads on the flasher over heating of the switch cam but I am hoping it’s a possible circuit problem in that the backup lights don’t work and they are off the same fuse as the turn signal lights. All other wiring off the fuse box to seems to work. The emergency flashers also work fine. Don’t know if they are cutting out the turn signal operation as it’s supposed to and then not restoring them. Is there a different flasher from the turn flasher? Hope it’s just the fuse. It looks O.K. from the floorboard, but I am having trouble getting it out and I don’t want to break the glass as has happened before. Should I jump the circuit to see if that 20 amp fuse is the culprit or could this do more harm than good? Big question, has there been any inprovement in the repo switches from the ones mentioned in the old threads??
Dale
Dale
