1970 service replacement rear spring? - NCRS Discussion Boards
  • D S.
    • March 1, 2005
    • 1551
    Re: 1970 service replacement rear spring?
    Originally posted by Jeffrey Salz (13182)
    If it's in as good shape as the guy says it does not need to be re-arched. New liners, painting is all that is needed. It may have been removed from a '69 but do you know for sure that it is original or just another replacement?
    Jeff
    Good point. What are sure-fire tell-tale signs to look for? Markings, part numbers, what?
    • D S.
      • March 1, 2005
      • 1551
      Here are three photos of the '69 rear spring that I may be getting. The owner was concerned it might be a service replacement because he said the plastic shims or liners were in very nice shape. Anyone know how to tell the difference between originals and service replacements?
      • Jeffrey S.
        • May 31, 1988
        • 1902
        In order to tell if it is an aftermarket replacement or original we need o see a picture from above of the ends of the leaves. Replacements have a tapered but straight outer edge whereas originals have a "scalloped" edge. I don't know if I'm explaining it right but I will "know it if I see it". Does this mean I am qualified to be a Supreme Court Justice?
        Jeff
        • D S.
          • March 1, 2005
          • 1551
          Jeff
          You know how us "purists" are, Judge. I will ask the guy to photograph it from the top. I want to know for sure before I go to cleaning it up and installing it.
          • Michael G.
            • January 1, 1997
            • 1251
            A top shot is ok but a good shot of the ends of the leafs would aid in making the call on originality.
            • D S.
              • March 1, 2005
              • 1551
              I went through the TDB archives and all I saw were distance photos of '69-'72 springs but I noticed they appeared to have a slight upward curl on the ends whether mounted on the car or just sitting on the floor. The one on my car sure doesn't. When I think of scallops I think of the perimeter edges of pie crusts but I am sure not that pronounced.
              Thanks for the suggestion.
              • Gary B.
                • February 1, 1997
                • 7090
                Scott,
                I'm pretty certain there are some photos in the archives showing the taper rolled ends on original springs. It's best to look at both a top and side view to confirm originality. And any 63-79 or so spring will do. You don't need to restrict yourself to 69-72. Also, imagining a pie crust doesn't help.
                There is a sketch from the side of a repro and an original in one of the articles on leaf springs that I wrote for the Restorer about 7 or 8 years ago. Can't remember the year or issue off the top of my head.
                Gary
                • Paul O.
                  • August 31, 1990
                  • 1716
                  Scott
                  From what I see in those photos it appears to be an original type rear spring.
                  1. The top 3 leafs are straight with no curved up ends
                  2. The liners also appear correct.
                  3. The bottom leaf end has the correct appearance.
                  4. Just need a better close up photo looking from the top and side of the middle 5 leafs at their ends as everyone else has pointed out.
                  Paul 18046
                    • 15646
                    #24
                    To add to Paul's comments, I really like the finish on that spring and if it found its way to my car I wouldn't touch it. I don't care what you do to it you will never make it original again.
                    • D S.
                      • March 1, 2005
                      • 1551
                      #25
                      I emailed Grant that if I got the spring I would clean it up and install it. But if I did that it would make the rest of the undercarriage jealous. By the way, I bought two pairs of those 1970 headlight washer check valves.
                      • Gary B.
                        • February 1, 1997
                        • 7090
                        #26
                        Scott
                        Paul 18046
                        Paul,
                        I'm not certain what you mean by "no curved up ends". All leaves, except the main leaf, should have the same taper rolled ends.
                        Gary
                        • Paul O.
                          • August 31, 1990
                          • 1716
                          #27
                          Gary
                          What I am saying is that the 5 middle leafs have a much more pronounced up ward curve then the top 3 shorter leafs. The top 3 have variations of the curve from none to very slight but not as great as the middle 5 leafs. Also if it were an F41 spring then I would expect the all 6 leafs to be curved up except for the bottom one.
                          I also agree with Terry leave the spring alone just install the bushing cups and install the spring. Do not forget that the bushing cup is flared over to lock it in the spring.
                          Paul 18046
                          • Jim T.
                            • March 1, 1993
                            • 5351
                            #28
                            Paul, I wouldn't know that as the spring might have been replaced before I bought it. Or I had it re-arched around 2005 maybe. Would clamps be installed after re-arching? I know that my mechanic and I talked about the rear spring about six years ago and he strongly advised against Fiberglas springs but can't recall what we did. Here is a photo that I hope will help.
                            What does your mechanic not like about composite/fiberglass springs? I installed one on my 1970 350/300 turbo 400 coupe about 22-23 years ago. Rear does not bottom out as experienced with the original steel spring when the 70 is loaded for a road trip. Does not squat and pull up the front end when power is applied. Liked it enough to install the same on my 68 327/350 4-speed about 12 years ago. Some 1981 Corvettes were the first to come from the factory with the composite/fiberglass rear spring.
                            • Jeffrey S.
                              • May 31, 1988
                              • 1902
                              #29
                              Here are 2 photos of an original spring, on the left in both, next to an Eaton spring.
                              Jeff
