Assist me with Validity of these 2 Cars - NCRS Discussion Boards
  • Gary J.
    • April 3, 2008
    • 153
    Please discuss if my thoughts are correct, I believe that one of these two cars is not correct. Both are presented as matching numbers, I am trying to utilize my knowledge to spot what I think is a problem with one car, both are very close in production dates. I provide some specifics but left off part of the vins to protect "the innocent" from my opinions.
    Both 1967 Small Block Convertibles
    Detail Car # 1 (I think correct) Car # 2 (questionable?)
    Body Date I 19 I 13
    Vin # 17, mid 500s 17, mid 600s
    Motor pad VO311 HE 300HP V0322 HT 350HP
    Build# A-3100s A-2300s
    Thank you for helping me to gain knowledge.
    Gary
    New England Chapter NCRS
  • Harry S.
    • July 31, 2002
    • 5330
    Re: Assist me with Validity of these 2 Cars
    Do you have the job sequence numbers?
    I think I see what you are saying. Looks like the earlier body hit the St. Louis line after the later body. Might be ok.
    • Patrick B.
      • August 31, 1985
      • 2003
      The surprising thing if these body tags are correct is that AO Smith build 800 convertible bodies in only 6 days at a time when the entire production of finished Corvettes , coupes and convertibles - STL and AOS bodies, was no more than 100 per day.
      • Robert G.
        • May 31, 1990
        • 429
        After several years of gathering data, I still don't know what I'm seeing with the AO Smith trim tag numbers. Here is a partial sampling of what I have around the time frame you're talking about:
        170xx...2391...I14
        170xx...3020...I17
        172xx...2981...unk
        172xx...2858...unk
        174xx...2591...H30
        174xx...3128...I19
        175xx...3153...I19
        176xx...2736...unk
        176xx...2331...I13
        176xx...3136...unk
        The 3000 group seems to make the most sense to me, but I can't believe that 7 out of 10 of these cars have either a gap or vin/body sequence order problem.
        • William C.
          • July 15, 2009
          • 239
          Gary..My 67 conv. body date I19 and build # A3131 with a NCRS validated production of 5-1-67. I agree the 2nd car looks suspect..Bill
          • Patrick B.
            • August 31, 1985
            • 2003
            170xx...3020...I17
            172xx...2981...unk
            172xx...2858...unk
            174xx...2591...H30
            174xx...3128...I19
            175xx...3153...I19
            176xx...2736...unk
            176xx...2331...I13
            176xx...3136...unk
            The 3000 sequence seems to make the most sense to me, but I can't believe that 6 out of 9 of these AO Smith cars are out of sequence with the vin sequence, some with a large number gap.
            Robert: Is the I13 body build car in your list the same car that Gary cited? Are all of cars on your list convertibles or are coupe numbers mixed in? Otherwise, how does an H30 body have a higher number than a I13 body?
            • Robert G.
              • May 31, 1990
              • 429
              Patrick, I believe it is the car Gary cited. The cars I listed are all convertibles. As you can see, there is such a discrepancy that trim tag swaps can't explain all this, and at this point, I wouldn't rely on the numbers/dates very heavily.
              • Patrick B.
                • August 31, 1985
                • 2003
                Robert: I don't think that it is necessary for the body build sequence to be the same as the VIN sequence because the bodies were ordered and stocked like engines whose build dates follow only a rough sequence with VINs. However, it does not make sense for the body numbers to be out of sequence with the build dates. If only the I13 car had a body number much lower than expected, the most logical explanation would be that someone had put a coupe trim tag on it (or made a phony convertible using a coupe tag as a model), since the cumulate number of coupes would have been lower on I13. However, your observation of an I14 car in logical sequence with the I13 car really adds to the mystery.
