Top generator bolt hole stripped out - NCRS Discussion Boards
  • Joe M.
    • April 30, 1990
    • 1342
    The bolt hole that receives the bolt that holds the long slender brace to the block is stripped out. I had to put a nut on th end of the bolt. What is the best way to fix this without purchasing a new generator? Can I purchase just the end plate?
  • Roger W.
    • January 29, 2008
    • 572
    Re: Top generator bolt hole stripped out
    How about a helicoil thread repair kit. Most any auto parts store carries them. All that you need to know is the bolt size and thread.
    • Thomas H.
      • August 31, 2005
      • 1068
      Joe,
      You could look for a donor generator of the same vintage and swap the end cover, but I'd be tempted to try the helicoil first as Roger suggested.
      If you have a local generater / alternator rebuilder, might be worth a phone call to them for suggestions also. I'm sure they have run across this in the past.
      Tom
      2007 Z06, Lemans Blue
      • Robert S.
        • May 31, 1988
        • 81
        This happened to my 60 and the heli-coil works well.
        • Tom P.
          • April 1, 1980
          • 1826
          If it were mine, I would not hesitate for 2sec to Helicoil it. Once the bolt is installed, the Helicoil is NOT detectable. And it will be a whole lot stronger than ever before!
          • Joe M.
            • April 30, 1990
            • 1342
            Thanks to all for the info; helicoil is shall be!
              • 43279
              Joe------
              Just make sure that when you drill out the existing threads and tap the hole for the Helicoil that you drill and tap STRAIGHT.
              • Bill M.
                • April 1, 1977
                • 1386
                I didn't strip the threads on my '59, but I did install a longer bolt and a nut on the back side so I could get more clamp load without stripping it.
                • Erich C.
                  • January 31, 2007
                  • 137
                  The Helicoils work very well. If you run into a problem installing it you could also use a thread repair insert like these:
                  McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
                  Erich
