1960 performance tire/wheel recomendations - NCRS Discussion Boards
  • George W.
    • May 31, 2000
    • 544
    Would like to put wider wheels and radial tires on my '60 Corvette.
    Criteria:
    1) Original looking wheel with provisions for full wheel hubcaps
    2) Correct hub size, back spacing, etc.
    3) High performance radial tires with wide white sidewall
    4) Do not want to modify or use spacers
    5) Must not be any clearance issues with suspension, fender wells, etc.
    Questions:
    1) Who supplies these wheels
    2) What is the widest wheel I can use
    3) What is the widest tire I can use
    4) Who has the best tires
    5) Would like the height to be as original so as to not have speedometer reading issues
    Thanks in advance,
    George
    geopar@gvtc.com
    210 748 4693
  • George W.
    • May 31, 2000
    • 544
    Re: 1960 performance tire/wheel recomendations
    Anyone?
    How about a link to past discussions? I searched without success.
    G.
    • Joe M.
      • April 30, 1990
      • 1338
      Contact Coker Tires and they can probably answer some of your questions. I would think you could go to Discount Tire and they could look at your rim size and tell you the largest tire that would fit on the rim. I doubt if you will find extra wide tires with correct whitewalls. Probably have better luck with blackwalls. If you mount a tire much larger than the original size, it will rub on the fenderwells. That is why hotrodders cut out part of the fender wells; then had to re-glass when their hotrod days were over.
      I believe you are asking for too many aspects for one tire to cover and still fit under your 1960. I own a 1960, but not a tire expert.
      • Steve V.
        • June 27, 2011
        • 95
        George,
        Wheel Vintiques makes a OE style wheel in several widths with the correct backspacing. The only problem you are going to have is nobody that I am aware of makes a wide wheel with the nubs. Some have welded a bead on the rim and I am sure that will work. I purchased their 6" wheels from Summit Racing and will be using either 205 or 215 tires from Coker on my '60.
        Steve
        Opportunity is missed by most people
        because it is dressed in overalls and looks like work.
        Thomas Edison
        • Robert S.
          • May 31, 1988
          • 81
          On the rear you can use a 7 inch wheel with 3.75 inch backspace. They can also be used on the front but will rub at full lock with 205 tires.
            • 15692
            There is no such thing as a "high performance" whitewall tire in a 15" size. Unless you're willing to go with blackwalls... game over.
            • Don H.
              • December 1, 1981
              • 1487
              The short answer is just put on radials that fit. In stock configuration they drive like a truck. A radial tire is a vast improvement over bias ply. I am not sure what you intend to do wanting high performance radials but in my humble opinion, they drive like a truck. I have driven mine many miles and have done many forms of racing with it. Did I mention they drive like a truck (compared to any modern car). Good luck, Don H.
              • Bill M.
                • April 1, 1977
                • 1386
                Here's some good info:
                http://forums.corvetteforum.com/c1-a...ight=backspace
                • Tom B.
                  • March 1, 1978
                  • 720
                  Wheelsmith makes classic and traditional style wheels for hot rods, custom cars, classic cars and street rods to order by real car guys in the U.S.A.
                  The Wheel Smith makes a wide wheel with the nubs in custom offsets. There was an article in On Solid Ground a couple of years ago on a 1960 with these wheels in 6" width and custom offset that filled the wheel wells just perfectly. 15x6 with a 3.5" back spacing.
                  I don't recall the tire brand or size right now. I'd have to look for it. I plan to run this wheel with 215/65 blackwalls though.
                  Tom
                  • Steven B.
                    • June 30, 1982
                    • 3995
                    I have seen some of The Wheelsmith units and they are very good. Tom, I can't remember the offset but I had 6" wide 5 spokes on the '57 with 7.75's (waaaay back when) and absolutely no trouble front or back, even under hard launches the rears didn't rub.
                    Steve
                    • Tom B.
                      • March 1, 1978
                      • 720
                      Hard launches in your '57? I seem to remember that. A few hard turns too.
                      • Steven B.
                        • June 30, 1982
                        • 3995
                        Yeahhh! I am choosing a new flywheel and clutch so I can try out the engine rebuild. 'Gotta get some new tires, too. The old Bucrons in the garage just aren't big enough--or enough tread--urrr carcass-- left. Those really were the good old days.
                          Steve -
                          I used to buy a nice new pair of 7.60-15 or 8.20-15 Bucrons every Thursday night at the Standard station on Woodward in Birmingham (Michigan) for my blown Buick "nailhead" V-8-powered '53 back in 1959; they were history by Sunday night. Paid the princely sum of $18.00 per pair in those days .
                          • Steven B.
                            • June 30, 1982
                            • 3995
                            John, I wish I had bought a few pair and stored them. That car with a nailhead must have been pretty quick! I used to go from NE Indiana to Detroit to the speed shops---Standard Auto Supply, Gratiot, etc. I did a little street racing around Kalamazoo and Coldwater but never Detroit. I did see some really hot machines there, though. I miss those days of inexpensive cars, tires and gas.
                            Steve
