54 transmission output shaft washer - NCRS Discussion Boards
  • Guy M.
    • November 1, 1993
    • 500
    Does the output shaft have a thick washer inside and was the special bolt used ( permits a small amount of fluid to pass through) like the passenger car output shaft. The yoke and output shaft fit fine on the bench but installed the yoke wont slide into place and seems too tight. It shoud slide together easily I would think.
  • Chris S.
    • January 1, 2000
    • 1068
    Re: 54 transmission output shaft washer
    There is a washer and bolt that hold the output shaft in place.
    The housing then bolts on.
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
