61 Blower Motor Wire - NCRS Discussion Boards
  • Dennis C.
    • June 30, 2002
    • 883
    Hi All,
    How long should the brown wire from the heater blower motor be?
    I am hooking up the motor on my 61 and the wire would be longer enough if streched and connected to the the back of the switch. The AIM showes the wire routing behind the defroster bracket that holds the defroster hose.
    The wire on my blower motor is 14". I have checked the usual sources for an extension cable but no one has one so I am thinking the wire should be longer.
    Dennis
  • Dennis C.
    • June 30, 2002
    • 883
    Re: 61 Blower Motor Wire
    One other question, what does the terminal that connects to the switch look like? Is it a plain female push on terminal or a plastic connector? If a plastic connector, what color is it?
    Thanks again.
    Dennis
    • John F.
      • March 23, 2008
      • 2395
      Dennis, the connector is open female that accepts the male spade.
      • Dennis C.
        • June 30, 2002
        • 883
        John,
        That was exactly what I needed. My wire has the same terminal on it, but it is going to be too short to route like that.
        Thanks for the information.
        Dennis
        • Bill M.
          • March 31, 1977
          • 1386
          Originally posted by Dennis Crupi (38211)
          Hi All,
          Dennis
          The original brown wire on my '59 measures 20 inches.
          • Dennis C.
            • June 30, 2002
            • 883
            Bill,
            That's just about the length I came up with after looking at John's photo. Thanks for the the confirmation.
            Dennis
            • Dennis C.
              • June 30, 2002
              • 883
              John, Bill,
              Wanted to thank you guys again. I replaced my blower motor wire over the weekend and reinstalled the motor back in the car. With the longer length wire everything fit together just like the photo.
              Thanks for the help.
              Dennis
              • John F.
                • March 23, 2008
                • 2395
                Dennis, That is what this forum is all about!
                John F
