Re: I was told not to install my new restoration battery
According to my Judging Reference manual, there is a 10% deduction for a battery appearing as described:
[p.139 of the '66 judging guide gives the exact descriptions of the battery, DC-12 #1980558 "Cat. No. 558" appears on the top edge of the case. The case is solid black without hightlighting paint on raised surfaces. The caps are black plastic screw-in types. The caps read "Delco" in large yellow letters across the center and "Fill To" on the op periphery and "Split Ring" on the lower periphery. The side of the battery nearest the terminals has the following:
DELCO DC-12
Original Equipment Line
Power Rated
All batteries are stamped with a production date and source code on one of the intermediate top covers. The format is YMS, Y for year, M is month, S is source.]
but without the appropriate date and plant stamping,
30% deduction for reproductions differeing from original design and construction in minor detail,
50% deduction for Delco, correctly sized, service replacement with
appropriate side or top post cinfiguration
100% deduction (Originality and Condition) for any others.
There is no description in the manual that the battery must be a "tar top" or even what that means or how you check. This battery is exact in every detail, and when properly stamped for date and source, gets no deductions.
In fact Larry, you are the one I listened to in 2009 on the R59 battery when you said:
"Ron:
I can't say for certain what the Lone Star Regional judges will actually deduct, but batteries are covered in the NCRS Judging Reference Manual under Section 4 Standard Deduction Guidelines:
Deduct 10% if the battery does not have appropriate date and plant stamping.
Deduct 30% for reproduction differing from original design and construction in minor detail.
For 1967 cars, I believe that the battery carries 25 originality points and 15 condition points.
For a current R-59 reproduction maintenance-free battery that is correctly date/location stamped, the originality deduction should be between zero to a max of 7.5 points. Since its new, there should be no condition points deduction.
I would expect a zero deduct, but some judges may find some differences and take the larger number. Judges have been known in the past to "thump" the top cover to see if the upper portion of the battery is hollow, or ask the owner to remove a battery cap to check for acid/lead plates. Other judges have not.
Larry"
BTW, I have not seen any judges thump on a battery. I think I would object were they to do that.
DELCO DC-12
Power Rated
"Ron:
Larry"
Then trailer the car to Novi and drive to Kansas City, MO to join the Midwest Road Tour. We travelled 1,200 miles to Novi for a Founders Ops check and receive the coveted NCRS Founders award.
