need a switch thats turns off vacuum pump - NCRS Discussion Boards
  • Mike M.
    • May 31, 1974
    • 8400
    need a switch that will turn off a 12 volt vacuum pump at 15" vac.the switch will need to be fairly small( tennis ball size or there-abouts). need a source. thanks,mike
    Re: need a switch thats turns off vacuum pump
    Mike -
    Lotsa hits here - one of them should have what you need.
    • John D.
      • December 1, 1979
      • 5507
      Hi Doc, If you would put in nice Duntov 097 cam instead of that poc 30-30 you wouldn't need a switch. True Story, JD
