54 starter doesnt engage fully sometimes. - NCRS Discussion Boards
  • Guy M.
    • November 1, 1993
    • 500
    Keeps hanging up, everything looks clean as far as flywheel is concerened. I have to turn the crank sometimes. Any Ideas. These starters engage straight on and seem to hang up on the teeth. Thanks as always
  • Willard M.
    • August 31, 1979
    • 422
    Re: 54 starter doesnt engage fully sometimes.
    I think that the first order of business is to remove the starter and get it rebuilt by one of the folks that are in the Driveline or even a local shop. This shouldn't be too expensive. My 54 was giving me similar problems and less than $50.00 solved the problem. My only issue was tightening the top starter bolt. I ended up making my own specialized wrench with necessary twists that I use just for that task.
    • Guy M.
      • November 1, 1993
      • 500
      Thanks Willard, thats what Im doing. Sometimes it engaged all the way and other times it would seemingly run into a flywkel tooth and hang up. Ill see soon enough.
