Transmission Tag - NCRS Discussion Boards
Transmission Tag
  • Dale C.
    • November 1, 1999
    • 844
    Transmission Tag
    I have located the correct transmission tag for my M20. Is there a problem with removing the single bolt and inserting the tag and then replacing the bolt? I was told once not to remove just one of the plate bolts. Can't remember why not to though.
    Dale
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: Transmission Tag
    Dale
    I can't see why not. All 7 sidecover bolts have "blind" holes -- ie. not tapped through the thread bosses into the gear lube. And they are relatively low torque fasteners (15-20 ft.lbs).
    • Michael G.
      • January 1, 1997
      • 1251
      Dale
      Be done with it.
