After 45+ years, the speedometer just quit. I found a seized cable which was replaced. I also found that the plastic gear inside the tailshaft was not contacting the drive gear on the output shaft, probably the result of the cable failure, so I replaced that too. I found a 'natural' 19 tooth gear inside the tailshaft, so that is what I put back in. Still no reading on the speedometer...
I spun the cable with a cordless drill, and got 20 MPH, so I assuming the speedometer and the new cable are not the culprit. I also tried turning the plastic gear, which has a little play, but seems engaged with the drive gear. Also checked to be sure that the square end of the cable went into the plastic gear which it does. After all the checking, the speedometer still reads zero.
Based on past threads, I am wondering if the diameter of the plastic gear is somehow the issue. Instead of the natural gear, do I need to switch to another color with a different diameter? I assumed that replacing the worn gear with the same type would work.
Thanks for any ideas, as this has totally stumped me....
Dan
