I am refinishing the soft top frame on my 58 project. I am having trouble understanding how the most forward, side weatherstrip is attached. The large holes on the forward arms do not line up with the holes on the metal weatherstrip retainers. There are small (sheet metal screw) holes drilled into the arms that seem to line up with the middle and forward holes on the retainers. However, I thought the retainers/weatherstrip were attached with T-nuts and machined screws. I do have the correct arms and I have the weatherstrip/retainer kit from C.C. If I attach the weatherstrip/retainer as I see it now, the furthest rearward hole gets a T-nut, and the middle and forward holes get sheet metal screws. Does this sound correct? Also, how are the 2 sections of the forward arms joined? I know how to attach the arm assmbly to the fron bow, but, there are 3 elongated holes in the upper portion of the arm assembly that line up with holes in the lower portion of the assembly...what are the correct fastners?
Jim
Jim
