1990 Brake Master Cylinder - NCRS Discussion Boards
  • George D.
    • August 31, 2000
    • 225
    I need to replace the master cylinder due to leakage between the MC assy and the brake booster. Any suggestions as to best supplier for a replacement or someone that can rebuild it? I would like to keep the car as original as possible since it has recieved a Top Flight at the nationals and been PV'd.
  • Erich C.
    • January 31, 2007
    • 137
    Re: 1990 Brake Master Cylinder
    If there is any pitting in the bore just rebuilding it might not last too long or it might leak from the get go. Another option would be to have it sleeved and rebuilt. That way you retain the original master cylinder and have a new wear surface ( bore ). Here is an example of some places that provide that service: http://www.brakecylinder.com/index.htm ,
    http://www.applehydraulics.com/brakes.htm ,
    http://www.resleeve.com/sleeving.htm .
    Erich
    • Pete B.
      • February 22, 2007
      • 326
      George,
      I rebuilt mine on my 89 Mclellan candidate, went fine. Easy job, parts from NAPA and the screw in cap that has the date code is left intact.
      Do check for corrosion but depending on the type of life the car had you probably will be fine.
      If all else fails you can buy a service replacement and switch the cap to the new cylinder. You may encounter other configuration issues though.
      Regards...
      Pete
      Pete Bergmann
      2005 - 2013 C6 National Teamleader
      • Peter M.
        • April 8, 2007
        • 570
        Erich
        Very good tip. Thanks for posting this information
