BW T-10 Gasket replacement - NCRS Discussion Boards
  • Philip P.
    • February 28, 2011
    • 558
    Being winter and nothing else to do I removed the engine and transmission from the car. It has a small leak between the main case and tailshaft. Any tips on replacing all the gaskets, transmission work fine so there are no issuses with that just the leak.
    Phil
    1960
    Re: BW T-10 Gasket replacement
    Phil
    1960
    Phil -
    The T-10 4-speed isn't included in the ST-12, as it was shared with passenger cars; the 1961 Passenger Car Shop Manual has a highly-detailed chapter on overhauling the T-10 - it's available from the NCRS store. There are four gaskets on a T-10; one for the front bearing retainer, one for the side cover, and two for the midplate (plus O-rings on the 1-2, 3-4, and reverse shifter shafts). Might as well replace the output shaft seal too while it's out of the car.
    • Joe R.
      • July 31, 1976
      • 4550
      Phil,
      The rebuild gasket set was PN 3960199 for the T-10.
      Incidentally the part number for the Muncie rebuild gasket was 3917763
      The above gasket sets are the bare bones and does not include the rear main gasket for the output shaft.
      Joe
      • Richard T.
        • February 1, 1979
        • 858
        Any brand of sealer work best? My 62 trans was done a couple of years ago and operates great but leaks more than it did originally. Rich
          • 6941
          Phil
          1960
          Phil, The gaskets at the rear tail and mid plate will basicly require dissy. of the transmisson, As John says a manuel is the only way to go if you haven't had any experience with the T-10.
          • Philip P.
            • February 28, 2011
            • 558
            Thanks all, I do have the 1959-60 Passenger Car Supplement and it covers the 4 speed. I did get a gasket kit with o-rings and tail shaft now I have to decide how I want to proceed. This whole project started with a cam switch and the engine is now going to be "refreshed", it is the "might just as well" because it is out of the car. Not enough room for the parts that have been ordered.
            Phil
            • Domenic T.
              • January 29, 2010
              • 2452
              Phillip,
              I don't have a borg Warner apart in the shop and have only done muncies lately, but I think there is a bolt that needed to be sealed that bolted the tail housing to the case.
              I did a lot of borg warner 4 speeds in the day and find myself still looking for the bolt to seal when I do muncies.
              I remember sealing bolts that entered the case and that may be the leak.
              DOM
              • Philip P.
                • February 28, 2011
                • 558
                Dom,
                Thanks for the information the leak is small I mean a drip. I will take a look at the bolts and see about sealing them that would make my day if I do not have to take it apart.
                Phil
                • Joe R.
                  • July 31, 1976
                  • 4550
                  Originally posted by Domenic Tallarita (51287)
                  Phillip,
                  DOM
                  Dom,
                  Think you are talking about the rear end of the countershaft. If it ain't sealed you can bet it's gonna leak.
                  JR
                  • Domenic T.
                    • January 29, 2010
                    • 2452
                    Joe,
                    Actually it was a bolt that I am almost sure goes thru the tail housing, center plate, and into the case.
                    I seem to remember using a sealer on the borg warner bolts.
                    I think the side cover may also have bolts that enter the case also.
                    DOM
                    • Tom P.
                      • April 1, 1980
                      • 1814
                      Joe,
                      DOM
                      That is correct!!! ONE bolt through the tail housing into the main case is a through hole.
                      • Joe R.
                        • July 31, 1976
                        • 4550
                        Joe,
                        DOM
                        Dom,
                        I'm on the right channel now! Yes, a bolt that holds the tail housing on and several side cover bolts. Never thought about it as I usually use sealant on all the bolts.
                        JR
                          • 6941
                          As does the front T/O retainer bolts go through the case. I just finished rebuilding a T10.
                          • Joe R.
                            • July 31, 1976
                            • 4550
                            Well, I'm going to retract what I said about the holes going thru in the rear and side cover. Well at least for the one on the bench which is a T-10 1C the rear bolts do not go thru and neither does any of the side cover bolts. They have raised bosses on the inside for all those bolts. The front bearing retainer does have holes all the way into the case.
                            Maybe some T-10's are different. Don't have the time to pull out all the cases.
                            JR
