Correct A.I.R. Pulley - NCRS Discussion Boards
  • Christopher K.
    • September 10, 2007
    • 311
    My GM parts book lists 3917234 as the correct pulley for all '68-'72 sb's with A.I.R.
    For '73-'74 the 3917234 is also listed for non a/c cars, but a different pulley is listed for C.A.C. (cars with a/c) - 3927116.
    Does anyone know what the difference is between these pulleys?
    Should my late (July build) '72 Lt-1 with a/c still have a 3917234 pulley?
    Thanks for the help,
    Chris
    Chris
    '72 Lt-1 a/c Pewter Silver coupe Mason Dixon Chapter Top Flight 2016
    '73 L82 4 spd Dark Metallic Blue coupe Chapter Top Flight 2023
  • Roy V.
    • April 8, 2008
    • 311
    Re: Correct A.I.R. Pulley
    Chris
    Chris, my L13 trim tag (July 13, 1972) LT-1 without a/c has the #3917234 pulley.Sorry I have no knowledge how it relates to the other pulley you mentioned.
    Regards
    Roy
    1972 LT-1 Elkhart Green Coupe
    • Christopher K.
      • 311
      Regards
      Roy
      Thanks Roy, that's helpful. Mine is L06.
      I know the judging manual only lists 3917234, but I was just curious if late a/c cars may have had the other pulley.
      Chris
      Chris
      • Jeff A.
        • January 1, 2000
        • 312
        the 234 is a deep groove pulley, 116 is not.
        If your other pulleys are deep groove you should use the 234.
        the 116 is a very common pulley widely used on low perf models.
        My Cars
        • Christopher K.
          • 311
          Thanks Jeff for explaining the difference.
          Chris
          Chris
