Non Corvette Question - NCRS Discussion Boards
  • Jerry C.
    • November 1, 1995
    • 741
    A buddy of mine just showed me a picture of a rat rod with what he was told by the owner it was a late 1930's six cylinder motor from a two ton truck. This motor had two distributors and twelve spark plugs. Did Chevy ever make such a critter? Thanks in advance.
  • Domenic T.
    • January 29, 2010
    • 2452
    Re: Non Corvette Question
    Jerry,
    With out a picture it's hard to ID, but I don't think chevrolet 6 cylinder engines ever had 12 plugs and 2 distributors.
    BUT,
    Aircraft engines did have dual ignition systems and plugs.
    I have a 6 cylinder, dual distributor, 12 plug blimp engine from 1914. The later engines mostly had dual magneto's.
    Sounds like a aircraft engine to me and I have seen them at the strip back n the 60's.
    DOM
      Originally posted by Domenic Tallarita (51287)
      Jerry,
      BUT,
      DOM
      Dom -
      Here's the first "Green Monster" Art Arfons built, which most people have never seen - I took the photo at the Akron dragstrip in 1957. It had a 6-cylinder Ranger aircraft engine, mounted inverted as it was in airplanes, with dual magnetos; note the primary chain drive sprocket, right next to your head.
      • Domenic T.
        • January 29, 2010
        • 2452
        John,
        Nice picture, I thought it was going to be the jet he ran as the green monster.
        I saw it run at US 30 dragstrip (Indiana) back in the 60's.
        I didn't know he had more GREEN MONSTERS untill I saw your picture.
        DOM
          John,
          DOM
          Here's the second one Art built, with an Allison V-1710 and a Greyhound bus transmission; he brought both of them to the strip that same day in '57. His feed mill was just up the road.
          • Domenic T.
            • January 29, 2010
            • 2452
            John,
            DOM
            I also saw the Allison run back then and if I remember they had 2 linked together and only one made it thru the 1/4 mile.
            The RPM's were very low and still are in the gas recip engines so they must have had a tall gear.
            Some of the old radials ran about 1500 rpm's at cruse settings and most today in the flat engines are 2700 rpm's & below.
            I guess they were thinking all bottom end when they ran them at the strip.
            DOM
            • Domenic T.
              • January 29, 2010
              • 2452
              John,
              Did he run the dual allison dragster or was it someone else. I saw one run in the early 60's around the same time I saw the jet dragster he had.
              DOM
              • Clem Z.
                • January 1, 2006
                • 9427
                a lot of fire truck engines used dual ignitions. some nash 6 cylinder engines use a dual dist with 12 spark plugs
                • Dick W.
                  • 10483
                  National Fire Codes at one time required dual ignition on class A pumpers. My guess it that he has a Waukesha, Continental, or Hercules engine. They were predominant engine suppliers for the fire service
                  Dick Whittington
                    • 15696
                    Takeoff power was usually rated in the mid-2000 range.
                    • Dick W.
                      • 10483
                      I forgot Lycoming and Mack. I have never seen anything but a V-12 Lycoming, but Mack did have a dual ignition gas engine or two
                      Dick Whittington
                      • John D.
                        • December 1, 1979
                        • 5507
                        Notice the 39 Buick behind old Art's dragster. First car I ever wrecked was a 39 Buick back in 1946.
