Replacement Ignition Coil C2 - NCRS Discussion Boards
  • Randy S.
    • January 1, 2003
    • 586
    Is there a Black generic ignition coil I can get at my local auto parts store to replace the 1115202 coil? ( 66 small block non TI)
    Local NAPA store offered 2 but they were both blue in color. Would like to get a black one.
    Randy
  • Donald L.
    • September 30, 1998
    • 461
    Re: Replacement Ignition Coil C2
    I believe NAPA sells the Standard Auto Products coil UC 12 which is black .
      Yup - looks like this - it's slightly larger in diameter than the 202, but still fits in the clamp.
        • 43248
        Randy
        Randy-----
        GM #12337166, aka Delco U505, is the "direct descendant" of the 1115202 and it's also black.
        In actuality, it might be the exact same piece as the Standard Auto Parts piece as the Delco might be manufactured by Standard Auto Parts. You can buy the GM/Delco coil for about 35 bucks. If the Standard Auto Parts piece at NAPA is about the same, I'd go with the Delco.
        • John D.
          • December 1, 1979
          • 5507
          That's really good info on the replacement coils men. Thanks very much, JD
          My office area is loaded with note-grams with a ton of your good advise here. Need bigger office. LOL
          • Michael F.
            • 745
            anything out there to replace and WORK with the TI ignition system???
            Michael
            70 Mulsanne Blue LT-1
            03 Electron Blue Z06
