1970-71 Nos Lt1 - NCRS Discussion Boards
1970-71 Nos Lt1
  • Paul Y.
    • September 30, 1982
    • 570
    1970-71 Nos Lt1
    I picked up an NOS December 10, 1970 dated short block in the original crate last week and I thought I would post some pictures of the markings on it and paint inspection marks. I can find a lightly stamped CE on the pad that is very faint.
    It's a good life!
  • Paul Y.
    • 570
    Re: 1970-71 Nos Lt1
    Here is a couple more. Can anyone tell me what these inspection marks mean on the block?
    It's a good life!
    • Timothy B.
      • April 30, 1983
      • 5196
      Re: 1970-71 Nos Lt1
      Paul,
      I can't help with the markings but that is a very nice piece.. Where did you find the motor..
        • 15706
        Re: 1970-71 Nos Lt1
        The crayon marks on the block may be from inspectors, and/or ID this job to receive the LT-1 crankshaft, however, the block is othewise identifiable because I think it was the only '70 SB machined for four bolt main caps.
        The "H" on the piston is probably the size group and there should be some codes underneath to indicate the piston size for each cylinder. The pistons were installed with the block upside down. There were about four piston size groups, and one was selected based on bore measurement for each cylinder.
        John Hinckley can probably provide more info.
        Is the cam sprocket nylon-tooth or steel-tooth?
          • 43248
          Re: 1970-71 Nos Lt1
          Paul------
          This is a 1971-72 LT-1 short block, not also applicable to 1970. Note the piston crowns. This style crown is the 9.0:1 CR used for 1971-72 but not 1970.
            • 43248
            Re: 1970-71 Nos Lt1
            Duke-----
            All 1970-72 LT-1 were equipped with 4 bolt main caps.
            If the installed camshaft sprocket is anything other than nylon-toothed aluminum I'll be amazed.
            • Stephen B.
              • April 1, 1988
              • 876
              Re: 1970-71 Nos Lt1
              I had a genuine NOS 1970 LT-1 short block a couple of years ago. It did not have any marking on it.
              • Steven G.
                • November 17, 2008
                • 348
                Re: 1970-71 Nos Lt1
                Duke-----
                I believe other small blocks used 4 bolt main caps as well, not just LT-1's, I'd expect to see the same on my L-46. Steve
                  • 15616
                  Re: 1970-71 Nos Lt1
                  The cylinder bore size codes were stamped on the oil pan rail while the case was upside down. I don't know what those codes were -- numbers or letters -- but they air-gauged the bore and lights on the machine told the operator what character to stamp on the rail near that bore. I would expect ALL small blocks from Flint to have these bore size stamps, and I would not be surprised that Tonawanda used a similar process.
                  Duke, I believe truck small blocks of this period also used four-bolt main bearing caps.
                    • 43248
                    Re: 1970-71 Nos Lt1
                    Steve-----
                    I did not say that other small blocks of the period did not use 4 bolt mains; I simply stated that all 1970-72 LT-1's were equipped with 4 bolt mains.
                    For 1969-70, all Corvette small blocks, base engine to LT-1, were equipped with 4 bolt mains. For the 71-72 period, some base engines may have been originally built with 4 bolt mains and some not.
                    • Paul Y.
                      • 570
                      Re: 1970-71 Nos Lt1
                      Joe, I figured that because of the December cast date. So would the 186 head of the 1970 engine up the compression? If so how much?
                      It's a good life!
                      • Paul Y.
                        • 570
                        Re: 1970-71 Nos Lt1
                        Tim, Thank you. I found it in a sub division of Denver on the local craigslist. It had been in the seller garage since the 70's sometime. It came from Burt Chevrolet, known as a high performance parts dealership.
                        It's a good life!
                        • Paul Y.
                          • 570
                          Re: 1970-71 Nos Lt1
                          Duke, the cam sprocket is nylon toothed.
                          It's a good life!
                            • 43248
                            Re: 1970-71 Nos Lt1
                            Paul-----
                            Sort blocks for SERVICE were produced for 1970 LT-1 applications as late as 1975. So, the cast date of the short block does not imply whether it's for a 1970 or later LT-1. It's the short block assembly PART NUMBER that identifies it as well as features like piston configuration.
                            The 186 head would up the compression ratio of this short block to ABOUT 10:1.
                            • Ronald L.
                              • October 18, 2009
                              • 3248
                              Re: 1970-71 Nos Lt1
                              What is important is what the casting date is...?
                              On those marks, as inspectors did their thing, it got a mark.
                              Terry, yes, I have seen them on the BB's from Tonawanda.
