Original Pan, Intake, Valve Cover Gaskets - NCRS Discussion Boards
  • Monte M.
    • January 1, 1991
    • 687
    I found a box full of gaskets. I know the box is at least 28 years old. It is full of GM big block oil pan, intake, and valve cover gaskets.
    Are these a find or are the new ones the same as these?
    What is it I am looking for if they are different from the new ones?
    Has the part number changed over the years?
    I know the much older ones had a little tab that said "GM". Can anyone tell me if the big blocks had the same tabs and where they are?
    Any help would be appreciated
  • Ronald L.
    • October 18, 2009
    • 3248
    Re: Original Pan, Intake, Valve Cover Gaskets
    Monte, send them to me to look at and I'll send back anything repro
    • Monte M.
      • January 1, 1991
      • 687
      How about if I just send you one set of each?
      • Ronald L.
        • October 18, 2009
        • 3248
        Monte, perfect!
        So the answer is a bit more detailed, these also were kits for the tall deck blocks, generally the rubber parts are the same and most important. Intake sides are worth 2 cents as a repro so if these are the dark gray and have the supplier logo, good stuff!
        • Wayne M.
          • March 1, 1980
          • 6414
          Monte -- here's where the GM is on the tab, at least on sets with the locating "tits". I have a couple of sets of BB gaskets, circa 1969. Also have other pics of the markings on the intake manifold-to-head gaskets, but I'd have to search.
