Pulley, oil filler cap finish - NCRS Discussion Boards
  • Jeff S.
    • July 31, 1984
    • 384
    Has anyone found a suitable rattle-can finish that approximates the dull, dark green phosphate coating found on some water pump & crankshaft pulleys & oil fill cap?
    Thanks in advance.
    Jeff
  • Ronald L.
    • October 18, 2009
    • 3248
    Re: Pulley, oil filler cap finish
    That is black oxide which is NOT an organic material of any sort.
    Black Oxide it. Anyone that pretends to put paint on them is usually hiding the blue that sneaks out from under the rivet of the 57 - 59 oil cap
    I have a place that can do it, but oil caps are tricky.
