C2 Antenna Mast - NCRS Discussion Boards
C2 Antenna Mast
  • John L.
    • 103
    C2 Antenna Mast
    When my original, rebuilt '66 power antenna is partially extended, I can manually raise the lower mast portion and pull it up from the base. Is this the way original units were designed to operate? Thanks
  • Ronald L.
    • October 18, 2009
    • 3248
    Re: C2 Antenna Mast
    John,
    Normal operation is to use the switch to raise and lower the antenna.
    Based upon the design of these modules it's a logical possibility to raise the non extended parts of the metal tube up because the cable that's on the hub gear is not at its' full end of travel.
