I bought my 72, with a 454 in it, about twenty five years ago. It came with the stock lower end, but the heads were the large port closed chamber heads. It had the GM LS-6, LS-7, single four barrel intake and carb on it.
I was told the cam is the 1970 365 horse cam. What I am getting at is, I know the large port stuff will really come into play at higher RPM than that engine will ever see, but what is the closed chamber doing for the engine.
I know this was not a well thought out engine.
I think he thought the closed chamber would up the compression enough to make it really run. It actually does alright.
The guy was smart enough to keep all the original parts that he removed. I got them when I bought the car. I am now putting the car back to stock looking. Smog pump and all.
THE QUESTION: Do any of you think leaving the closed chamber heads on the engine will be a benefit. I am putting the stock oval port intake back on the engine along with the original exaust manifolds.
I plan on buying a special grind cam to make it sound pretty and maybe even run a little better. I still want to run pump gas, but want it to run well.
I am replacing the pistons, but I would have to raise them quite a bit to get the original heads to get that motor going.
I am open to suggestion with using some or none of these parts.
Thanks for taking the time
