Knock off cones rattling - NCRS Discussion Boards
  • Tim D.
    • September 1, 2009
    • 238
    What is the best product to use to keep my Corvette America reproduction 63-64 knock off cones from rattling? I am considering clear silicone caulk or double sided foam tape. Any suggestions that will solve the problem, leave a clean appearance and hold up when I remove and reinstall wheels multiple times would be greatly appreciated.
    I origially used Permatex 2 non-hardening form a gasket but it is dark gray and really sloppy looking.
    Tim
  • Nick K.
    • December 1, 1999
    • 75
    Re: Knock off cones rattling
    A couple of thick bead's of clear silicone caulking/sealer spaced apart a couple of inches around the interior circumference of the cone has worked well on my older '63 Western Wheels KO's.
    Nick Kammer, #33307
    Chairman
    Miami Valley Chapter (Dayton, Ohio)
    937-602-8829
    • Paul J.
      • September 9, 2008
      • 2091
      Post #32 has pictures of what Nick is describing.
      https://www.forums.ncrs.org/showthre...89781&uid=9665
      • Chuck G.
        • May 31, 1982
        • 2039
        When I had repro KO's on my 63, I used double sided tape on every other/every third "spoke" behind the cones. Worked well, and wasn't as "messy" and gooey as silicone.
        Chuck
        • Tim S.
          • May 31, 1990
          • 715
          Some foam tape like used on truck caps. Tape it to the cone. I did not dream that up on my own. The prior owner used it on the original KH wheels.
          Tim
          • Carl B.
            • March 1, 2007
            • 89
            double sided tape works on older western wheels used 3m tape
            • Frank E.
              • May 31, 1986
              • 189
              I've used double sided foam tape for 25 years....
              Frank
              1966 Milano Maroon Roadster
              2004 CE Z06
